Dial A Jet!?!?!
Old Aug 23, 2003 | 11:03 PM
04SuzukiZ250's Avatar
Default Dial A Jet!?!?!
how does that thing work
Old Aug 24, 2003 | 03:28 AM
bigugly's Avatar
Old Aug 24, 2003 | 09:46 PM
Ronnnnn's Avatar
does exactly what it is supposed to do
Old Aug 25, 2003 | 06:09 AM
MBrooks420's Avatar
Its an external variable valve sized jet. It replaces the main jet, and makes the jetting fully adjustable externally with a screw driver.
Old Aug 25, 2003 | 09:09 AM
SHOTGUN's Avatar
Go two sizes on the mains, install the dail-a-jets in the carbs boot. ajust as needed.
Old Aug 25, 2003 | 09:55 AM
GR8T250R's Avatar
They have a site that explains it well. I think it is Thunderproducts.com.
Old Aug 26, 2003 | 02:47 PM
95wolv's Avatar
It doesn't replace the main jet, it adds finely emulsified fuel into the carb intake to fill the gaps the fuel droplets leave in a standard carb. You need to go down 2 sizes on the main to create a lean condition, the Dial a Jet feeds in fuel because of the pulsations caused by a lean condition, it is totally automatic, and only adds fuel when needed, not at idle,or revving in neutral, only when the engine is under load and needs extra fuel. From what I have read and heard, it works great, and is easily set for different conditions, you change your pipe, couple of clicks, and you are ready, you go to high altitude, you lean it out, no plug fouling, remove the air box lid, make an adjustment, all without having to pull the carb. Hope this helps explain a little, I may have left out the real specifics on how it functions.
Old Aug 26, 2003 | 02:55 PM
so i dont have to take the carb apart and change the jets when i can use a dial a jet and just press a button and it does it for me?
Old Aug 26, 2003 | 03:21 PM
95wolv's Avatar
Pretty much, you need to drill and tap a hole in the bottom of the bowl to mount the fuel line fitting, or use the overflow outlet, then put a small hole in the air boot or carb mouth to mount the inlet tube. There is a small dial on the tube you set with a small screwdriver to let more or less fuel in.
STLyamwar
Jul 25, 2020 04:44 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Mphillips
Jun 26, 2015 03:52 PM
coolhuh
Jun 24, 2002 04:05 PM
sparkys
Jan 30, 2002 10:31 AM
