can u put 93 octane in a stock z250?
Old Sep 6, 2003 | 09:08 PM
CHEWBACCA's Avatar
Default can u put 93 octane in a stock z250?
my friend does with his blaster and his quads faster. but his is a 2 stroke.
Old Sep 6, 2003 | 09:12 PM
scrambler123's Avatar
93 octane would be fine in a z250 although it would be unnecessary and a waste of money.
Old Sep 6, 2003 | 09:57 PM
Slacker1bob's Avatar
Technically, the lower the octane, the better the performance. As long as the quad doesnt have high compression or ping.
Old Sep 6, 2003 | 11:17 PM
SRK399's Avatar
How would lower octane be better?!?! Higher flashpoint? Higher temps?
Old Sep 6, 2003 | 11:35 PM
instigatr's Avatar
93 refers to the octane rating, or the ability to resist preignition (pinging)
the higher the number the better it resists. what this means is the fuel will not ignite as well. that is why a diesel engine has high compression. it can use a really high octane rated fuel.
so, i agree with the other guy (don't remember who). don't use the high octane unless you need it. you will have more power.
also it is a commom misconception that higher octane will give you more power. the ONLY way you will get more power is if the engine is pinging on low octane gas. when it pings the gas is igniting to early, there fore trying to force the piston down early, which causes power loss.
hope that makes sense
aaron
Old Sep 6, 2003 | 11:40 PM
SRK399's Avatar
Ahhh, makes perfect sense now, thanks for the clarification.
BTW: where is Colville WA? Im in Vancouver, right across the river from Portland OR.
Old Sep 7, 2003 | 12:01 AM
Actually a diesel engine has high compression because it doesnt have spark plugs. The compresssion ignights the fuel, so the octane really isnt that high in diesel fuel
Old Sep 7, 2003 | 12:11 AM
SRK399's Avatar
Yeah, I heard the glow plugs are only used when starting it. So is diesel fuel have a high or low octane? 93...? 89...?
Old Sep 7, 2003 | 12:58 AM
Sdcali15's Avatar
I don't know about the octane rating of diesel fuel.....it simply ignities a lot easier than gasoline
Old Sep 7, 2003 | 01:44 AM
SRK399's Avatar
Alright, thanks for the info guys.
