LT250R weird head gaskets ????
The head and gaskets from any year will physically fit on the studs from any other. But as stated allredy the head has a different vulume (CCs) and the gasket has a slightly different bore so it would not likely fun the same.
I forget who made the head gasket I put in my 91 LT but it had smaller holes than the one it had on several of the passages. I drilled them to be the same as the one I took off to be on the safe side.
i use comet gasket kits from www.moto-man.com there pretty good ive never had a blown head gasket, but it is stock bore gasket. I just resleved my cylinder and brought my commpression up, it was gettin pretty low, it is stock size now.
1ArmBandit
55
Oct 14, 2015 09:03 PM
85, cage, cometic, direction, fitment, gasket, gaskit, head, headgasket, holes, installation, interchange, lt250r, oem, reed
