My ATV is making a very strange noise...
I have a 1987 Suzuki LT230S. I recently replaced the engine case on the opposite side of the clutch cover. I put it back on, and started it up. For about 10 minutes, it sounded great. Then, I stopped, and it weas making a strange noise. It sounded like something was vibrating, inside the case. You can even hear it when I hit the kick started, even lightly. It still runs perfectly fine. Now I don'tknow whether or ot to ride. :\ Does anyonew know anything about this?
Personally I'd remove the cover and inspect it, make sure there is no debri loose in there. As far as the non-fitting bolt, silicon wont help it much, it'll just lightly seal around it. So...is the hole stripped where this bolt is going in, or the bolt for that matter?
MikeyBoyesq
08-10-2015 11:11 AM
