z400 flaws
Old Oct 11, 2003 | 12:27 AM
Rider1169's Avatar
Default z400 flaws
hey z400 owners, is there any down sides to your z400's? anything at all or even annoying things like bad positioning and things like that. thanks-rider
Old Oct 11, 2003 | 06:53 AM
Blaster2fast's Avatar
Default z400 flaws
the only thing i could say is its low RPM rev kinda slow.. could improve a lil there... other then that i love it 100% much much much better than my old blaster
Old Oct 11, 2003 | 10:15 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default z400 flaws
The stock engine doesn't have a lot of off-idle power (the engine doesn't like to lug down), compared to say the 400EX for example. You have to run revvvvved out, well past that spot. Combine this with a light flywheel, and it makes very slow, technical trail riding a bit of a pain.
After putting on an aftermarket header and muffler (FMF PowerBomb and Ti-4), the low end really woke up!!
Old Oct 11, 2003 | 10:19 AM
Lightman02's Avatar
Default z400 flaws
none on mine, just that the a couple od bolts came out of the plastics.
Old Oct 11, 2003 | 01:36 PM
RedNeckMXRider2's Avatar
Default z400 flaws
i herd the shock mounts on the front end i dunno if it true but thats what i herd
Old Oct 12, 2003 | 01:46 AM
chuck1221's Avatar
Default z400 flaws
The only flaw I could possibly see is the axle, My quad had the updated one and it still bent a little. Not a problem though, dealer covered it under warranty. I have took a couple really hard flat landings off a 35+ ft. table and the shock mounts look like new. I agree the stock motor has not much power and needs to reved waaaaay up. I am going to gear down a tooth and do a couple other small mods to help though.
chuck
Old Oct 12, 2003 | 03:47 AM
WhiteZee's Avatar
Default z400 flaws
No complaints with mine. As for the low end power when stock, try going to a 13 tooth front sprocket, it will give you plenty of low end. I never left mine stock for very long, did an intake mod after about 4 hours of ride time and that woke it up some.
Old Oct 12, 2003 | 08:23 AM
truckpaul's Avatar
Default z400 flaws
The only problem i had with mine was the steering tie rods. One bent during a not-too-hard day of riding. I just removed the tie rods and put steel rods inside the hollow aluminum and haven't had any problems since. Also fixed the low rev problem with a pro desing air kit and white bros exhaust. Rides like a raped-ape now!!!!!! LOVE IT!
Old Oct 13, 2003 | 10:43 PM
outNfront's Avatar
Default z400 flaws
did you jet it ?
Old Oct 14, 2003 | 06:56 AM
Zhvonte's Avatar
Default z400 flaws
Really the only issue I had last year on the stock quad was frame and axle. But they have since then fixed that problem. I bent two axles before upgrading and crack the frame right where the shock mount is twice.
Other than that, its been good stock and I rode the holy **** out of it.......
