Help with tires for King Quad!
Can anyone shed some light on what's the best way to go for a big wheel kit for the king Quad? I'm considering 25x8x11 fronts and 26x12x12 rears...anyone have first hand experience?
Do not use those big of tires your high range will be useless. I know first hand that using Bear Claws 24x9x11 on the front and 25x10x12 on the back. You can stall the motor going up a hill. That is about all the more tire that quad will need. The Bear Claws work real good to. Do not use a tire wider than nine inches on the front it will hit the tie rod end.
Frisky2050
Apr 9, 2020 11:19 AM
