will this work?
Old Nov 4, 2003 | 09:46 PM
killerfast's Avatar
Default will this work?
will 300 or 400ex or other shocks fit my 1986 lt230s? thanks
Old Nov 4, 2003 | 10:13 PM
MBrooks420's Avatar
Other shocks from different models will fit, but will sometimes need to be modified. I have seen 230's with Blaster shocks, but they weren't factory yamaha. I doubt the stock Blaster shocks would be a good idea due to the wieght difference in the machines.
Old Nov 5, 2003 | 05:52 PM
killerfast's Avatar
but will the 300ex shock work jus the back one
Old Nov 5, 2003 | 05:56 PM
MBrooks420's Avatar
You'll have to get the measurements of the 300ex shocks mounts. If they are too wide you'll need to cut them down and get new bushings.
Old Nov 5, 2003 | 06:00 PM
killerfast's Avatar
so a blaster shock will work for sure
Old Nov 5, 2003 | 08:30 PM
MBrooks420's Avatar
I'm not sure if it requires modification, but if it does it is simple. The kid I knew who had the blaster shock on his 230 wasn't very bright, and he put it on by himself.
Old Nov 6, 2003 | 07:24 AM
vexing2's Avatar
the lenght of the shock has been my biggest worry.... I believe the blaster shock is close to 16 inches long !! I picked the 300ex front shocks to try because they are around 2 inches longer off the bike... I am wondering now if different a-arms or, swingarms might fit?? newer shocks have a wider mount at the bottom... I don`t have acess to alot of parts and, I don`t want to spend a bunch of money to find out...LOL !! someone had a post saying they had a shock on the rear... but, it seemed you woukld have to mess with the airbax....it was in "your 230" I think
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
