Pro Design Cool Head what dome size???????
Old Nov 11, 2003 | 06:30 PM
strokertwo's Avatar
Default Pro Design Cool Head what dome size???????
What is a good dome size to run on the 87lt250r with the prodesign cool head 22cc or 23cc ?
What to stay with pump gas.
Thanks
Old Nov 11, 2003 | 11:08 PM
NichelsonRacing87's Avatar
i'm pretty sure it doesn't matter what dome size you get because it's really only increasing cooling effciency. i also own a 1987 LT250R and was deciding on ordering a Pro Design Cool head for it. i would recommend getting reference from an Atv or Motorcycle repair specialist first.
Old Nov 12, 2003 | 08:34 AM
strokertwo's Avatar
So there is no performance gain on using the cool head?
Has anybody use a prodesign cool head and what are the + or -?
Old Nov 12, 2003 | 09:51 AM
badchad's Avatar
Correct me if I am wrong, but I thought that by changing to a smaller dome would increase compression and give more power advantage. I don't run a coolhead so I can't tell you the answer, but the theory makes sense.
Old Nov 12, 2003 | 10:51 AM
sam250's Avatar
It's basic physics - The amount of fuel is the same so if the voulme is smaller then the pressure (compression) must be greater. Higher compression (smaller dome) = more power, but can also cause predetonation with pump gas.
The cool head makes more power by keeping your combustion chamber cooler and a smaller dome makes more power the same way shaving the head makes more power.
Old Nov 12, 2003 | 12:31 PM
strokertwo's Avatar
Is it worth the money for the head?, will you notice a performance increase and if so where low end ,mid or top end?. Looking for someone who has use one or has it on there bike now.
Thanks
Old Nov 17, 2003 | 11:34 PM
i would image a power increase since cooling effciency is increased, because the cooler an engine runs the more power it can produce over a longer time period.
Old Nov 19, 2003 | 08:02 PM
Halfliter's Avatar
You might want to do a search on cool heads in here. A while back was a pretty good discussion on them. In short, I absolutely hate them. They could have worked but have a few bad designs. JMO.
Schneider
Jul 24, 2015 05:05 PM
metal249
Jul 24, 2015 01:00 PM
Jul 23, 2015 11:46 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
