Suzuki LT 80
Old Sep 30, 1999 | 12:30 AM
ldemarce's Avatar
I just bought an LT 80 used. It almost runs, it will idle with the choke on, but not with it off. And when I run it with the choke on it bogs down and dies whenever I give it gas. I have tried cleaning the gas tank, carb, air filter. Replaced the spark plug, fuel valve, needle and seat in the carb. The odd thing is that when I tried running it with the fuel line off, it ran great until the carb ran out of fuel. Anyone have any suggestions. I appreciate it, Leah
Old Oct 3, 1999 | 08:59 AM
SnowJer's Avatar
did you replace the fuel valve with another origional valve? The stock valve isnt supposed to let fuel come out unless the engine is running.Also did you check the compression?
Old Oct 5, 1999 | 02:00 PM
hot_shoe_cv's Avatar
If it won't run unless the choke is closed, it's obviously getting more air than gas. Have you checked the boots on the carb to see if they're fully on & tightened & are there any weather cracks in them? It sounds like it's sucking air someplace.. the part about the fuel line is weird, no clue on that.
THE AZ HARD PACKER,
calmiller@kachina.net
save your riding area! join the Blue Ribbon Coalition online @www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 10-05-1999).]
Old Oct 5, 1999 | 02:22 PM
ldemarce's Avatar
After going through everything possible, I bled the fuel line (again) and it works like a charm. Go figure. Thank you both for your help though. Leah
VABrute
Jan 6, 2016 07:39 PM
clscott84
Sep 21, 2015 10:16 AM
merryman
Sep 19, 2015 03:15 AM
jsmit116
Sep 18, 2015 10:34 PM
Sep 1, 2015 11:59 PM
