Top speed LT250R?
Old Oct 5, 1999 | 11:17 PM
jus650's Avatar
Does anyone know the top speed of a LT250R? What is highest speed you could make one go with modifications?
Old Oct 6, 1999 | 01:38 AM
RoostKing's Avatar
It all depends on the modifications. I was thinking about transplanting a jet engine out of a f-15 Strike Eagle. That should do quite well. (Until, of course, I can get a Harrier "jump" jet engine. The jumping possibilities are endless....)I have only needed to wait for the chance to actually get an engine. Seriously, I would think that a totally moded lt 250 R with the correct motor would top out at 75-80 mph, give or take a little.
RoostKing 85 LT 250 R
Old Oct 16, 1999 | 07:56 PM
mojave4's Avatar
I read in a magizine a stock 250R tops out at around 68mph.
Old Nov 3, 1999 | 03:02 AM
BlackHawk's Avatar
I think the surface your running on has more of an effect on top speed than anything. I ran my LT with stock tires, stock gearing, an FMF pipe/silencer after a CT rebuild (the piston was only .25mm over) and hit 78 MPH while running on a hard pack, dry lake bed - just about the best surface you can get on for top speed. Compare that to the same machine on a regular loose dirt road doing about 60 top speed. You can make a Suzuki LT250R go a couple of hundred miles per hour too! Just drop it out of a plane. And if you want to use it after you arrive at the ground bring a parachute.
-Chris Olson "The Black Hawk" 1990 CT LT250R, 1987 Mojave Green&Mean I'm always 100% right so don't even ask :P
Pehter
Oct 3, 2024 11:00 PM
Levi Enstad
Sep 26, 2015 08:00 AM
ReconBayou
Sep 23, 2015 02:41 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Halffast17
Sep 11, 2015 02:30 PM
