2000 quadmaster 500
Old Oct 21, 1999 | 05:29 PM
lyle1's Avatar
Attn : Quadmasterbound
In response to your question about the typical belt lag time with a polaris jumping over logs...the suzuki doesn't have it. The throttle response is immediate with no hesitation; it simply feels that you are riding a geared machine. I regards to the hogh low problem you mention with the sportsman...it doesn't exist on the suzuki either. Low range is used during extreme hill climbs or if you stuck in mud. The gearing on the suzuki is lower than the polaris so you can use high range 90% of the time. On the downside I find that at higher speeds 40-50mph the suzuki tends to scream even though the motor is designed to do so. The suzuki is a great machine; it just falls a little short of what I want in a quad. It is all personal preference. Good luck
Old Oct 21, 1999 | 08:35 PM
quadmasterbound's Avatar
Thanks a million Lyle1. I really appreciate your input and definitely makes my decision easier. You outta consider writing quad reviews for a living. That is if you don't already. thanks again
Old Oct 21, 1999 | 09:16 PM
BONER's Avatar
lyle 1,
You are right about the motor. It revs like crazy. A banshee owner was amazed at how high it would rev. it even runs cooler at its top speed than it does at any other speed.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
