1998 Suzuki King Quad
Old Oct 18, 1999 | 09:17 PM
wcrook1007's Avatar
The problem is the neutral light some times comes on and sometimes not when you turn the key on and when it does'nt you have to pull start it what could be wrong.
Old Oct 18, 1999 | 10:52 PM
hot_shoe_cv's Avatar
I have a 96 KQ and have never had that problem, so the first thing I would do is to check you lights when it happens. If the lights are dim or off it is probly a dead cell in the battery. If light are normally bright, it sounds like a loose wire somewhere. You might start by checking the battery cables for good connections or
corrosion, but if you have lights, that's not likely the problem.
THE AZ HARD PACKER,
calmiller@kachina.net
save your riding area! join the Blue Ribbon Coalition online @www.sharetrails.org
Old Oct 19, 1999 | 01:56 PM
ecbaatz's Avatar
My first impression would be the ignitition switch itself. The switch can be placed in postions that do not line up properly. Example on Tour de Forest I thought the headlights were on since the switch was in that position (or so I thought) but I was able to move it a little more to get the lights on.
Second impression would be the neutral switch itself. It might not be closed all the way whent the transmission is in neutral. Starting it with the pull starter might jar it enough to close it.
Hope this helps.
Eric Baatz 1996 Suzuki KING QUAD Remember the KING Lives!!
Old Oct 19, 1999 | 03:43 PM
Brian_Kimmel's Avatar
Sounds like it could possibly be your neutral switch. I had the same problem with my Timberwolf. When the neutral light would come on it would start fine, but when the neutral light would not come on I had to pull in my brake lever to activate the start in gear switch and then it would start right up.
Brian Kimmel - 97 Timberwolf
Old Nov 5, 1999 | 02:09 PM
Zukimoto's Avatar
It could be your reverse switch located under the airbox. You can test the reverse and neutral switches using a factory service manual. You might be able to obtain photocopies of the procedure if you don't want to buy the manual.
jaime511
Jul 19, 2015 01:58 PM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
D-Hagz
Jul 4, 2015 02:19 AM
