Vinson 500 Problem-Need Help!
Old Dec 23, 2003 | 10:47 AM
stl14's Avatar
Default Vinson 500 Problem-Need Help!
I have an 04 Vinson Camo Auto with about 60 miles on it and the strangest thing happened yesterday. I was hunting about three hours away and from home and loaded my Vinson up in the back of the truck and drove home. It was pouring rain the entire way. Once home I started it up and it was making a grinding noise, it was still raining so I hurried up and pulled it in the garage. When I went to shut it off it wouldn't turn off. I tried the key and the stop switch and it wouldn't die. Finally I put it in reverse and the noise stopped and I shut off. I went back out a few times throuhout the evening and started it up and it sounded fine. Any idea what that could of been? It was in the shop last week for a complete service. Thanks!
Old Dec 23, 2003 | 05:26 PM
hondabuster's Avatar
I had a similar experience on my ozark. t was damp and rainy, and after I started it, it sounded like the starter was trying to engage, all on its own. Hasnt done it again. I was thinking it might be the rain/water getting into the handlebar switches and shorting things. I think when it gets warmer, im going to silcone caulk the area around the switches.
Old Dec 24, 2003 | 07:54 AM
stl14's Avatar
Thanks,
it did it again last night and I called the dealer and he told me to drop it off this morning. He said it was a stuck cylinoid. Who knows, I will post what it was when I get the bike back in case anyone else ever has this problem.
Old Dec 24, 2003 | 09:47 AM
Vinson581's Avatar
make sure the starter button didi not get wet, and did this problem only occur while brakeing?
Old Dec 24, 2003 | 09:57 AM
stl14's Avatar
Like I said it was raining hard the whole way home so anything is possible. The noise starting as soon as I started it up. I drop it off in about an hour so I will let you know what the dealer says. He swears it is a stuck cylinoid.
Old Dec 24, 2003 | 10:37 AM
Vinson581's Avatar
sounds like the problem, and the starter is always ingaged
Old Dec 24, 2003 | 12:45 PM
stl14's Avatar
Well thanks for your help guys, I just got my bike back and the dealer replaced the cylinoid and said that was the problem. Runs great now.
Quadmaster00
Jun 11, 2021 08:54 AM
panicmanic
Aug 11, 2015 06:50 AM
Sylvain97378
Apr 10, 2002 10:44 PM
markdf
Mar 18, 2002 02:23 AM
Phoneguy
Jan 8, 2002 03:34 PM
