high octane
Old Dec 28, 2003 | 12:12 PM
MBrooks420's Avatar
Default high octane
If all other things are equal, the higher octane will give slightly LESS power due to the higher flash point, and it being slightly harder to ingnite. Your Z250 should run fine on 87 octane. Anything over 89 is just a waste of money(for the motor you have)
Old Dec 28, 2003 | 01:08 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default high octane
The increased performance from Ultimate 4 (octane=92.2, not much more than pump gas) is because it runs LEAN! If you are jetted a little rich, that might be OK, but if your jetting is spot-on, going leaner wouldn't be a good thing.
Old Dec 28, 2003 | 10:30 PM
Slacker1bob's Avatar
Default high octane
MBrooks420
Exactly
Old Dec 28, 2003 | 10:54 PM
SukiZ400rdr's Avatar
Default high octane
I ran a mix of about 3/4 tank 92 octane and 1/4 tank 110 octane in my 96 mojave, and I DID notice a difference.
I dont know the compression ratio of the Z250, but the mojave is 11:1. I was told that by running higher octane,
the motor would run cooler, therefore more efficiently. That is where you see the difference. It probably doesnt
give you more power, it just doesnt lose power.
My 2 cents.
P.S. PACKERS are in the playoffs!!! (not that this has anything to do with ATV's, just couldnt help it!!)[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 30, 2003 | 11:45 AM
  #15
GTFZ250's Avatar
Default high octane
Thanks a ton for the info you guys!
Yea did you see that catch the cardinals made to beat the vikings. WOW
Old Jan 2, 2004 | 12:20 PM
  #16
Zhvonte's Avatar
Default high octane
I run 115 octane race fuel (VP C-15). I only run this octane because of the compression I am running.....
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
fredrikrosen
Sep 28, 2015 09:58 PM
r1pilot83
Sep 27, 2015 07:38 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
