Z250 Shifter
Old Jan 12, 2004 | 11:10 PM
mudAGoGo's Avatar
Default Z250 Shifter
My son has a Z250 and has some trouble shifting while using his riding boots. Has anyone put a new shifter on the Z that is an inch or two higher to improve the ability to get your foot under the shifter? Also any recommendation for _flexible_ riding boots would be great.
Thanks
Old Jan 12, 2004 | 11:30 PM
SpankyLowe's Avatar
Just loosen the shifter and move it up a tooth or two as I think we all have had the same problem....
Old Mar 25, 2004 | 09:04 PM
TomZ250's Avatar
i have oneal riding boots and after a while they flex great, yeah i know what your saying with the shifter its hard at first but they break in after a while
tom
Old Mar 25, 2004 | 09:09 PM
BrocksZ's Avatar
I actually had to adjust my shifter down a little so I didn't have to pull up so high to shift.
Old Mar 25, 2004 | 09:58 PM
LT249r's Avatar
I had the same problem. All you have to do is to adjust the lever. Or just use the boots a lot and after a while they will break in and it will stretch and be flexible.
Old Mar 25, 2004 | 10:47 PM
SpankyLowe's Avatar
Yep,just move it up one tooth and it will be fine..
Old Mar 25, 2004 | 11:02 PM
Perwho's Avatar
Do like they said as far as moving it a tooth or two, and then you can fine tune it where the 2 little black boots are there are locking nuts on a small shaft. Break both nuts loose and then turn the shaft in the direction you want it and then lock em down... As far as the boots go.....I've never tried it, but as long as the boots are a dark color I bet you could use glove oil for baseball mits on them.....anyone?[img]i/expressions/face-icon-small-wink.gif[/img]
Njrider1230
Jul 29, 2023 05:16 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
frostphase
Aug 19, 2015 07:11 PM
