What do you use to get the shine back in the fenders?
I let a friend use my Z400...Came back with some nasty Scratches, they were deep and ugly on the front and rear fenders.
I wet sanded them and the scratches came out pretty well but no buffing compound seemed to work to get the shine back. I am in the auto business so I have use of Buffers, compounds and cleaners.
I just couldnt get the spots I sanded to shine. To make matters worth the Quad has only had two gas tanks of gas through it. I could have killed him....o well, my fault. But now I would like to get those nasty dull spots of my fenders.....
Please help
Thanks
Steve
Please help
Thanks
Steve
Well, since you have already wet sanded them, try Plastic Renew from PC racing. I don't think it's that good, I used it once and the process didn't work too well, but since you already did the sanding part this is probably the best option. I use armor all on my plastics and it works better than anything I've tried. But that's smooth unsanded plastic.
I had some deep scratches on my wifes Scrambler. I sanded it and it made it dull. I used a heat gun to remove the scratches the sand paper left. It also brought back the shine. On the real deep ones I heated it up and then used a putty knife to smooth it. Don't get it to hot or it will warp, go slow. After that I used some son-of-a-gun to make it shine even more. On my Vinson I used Armor-all to make it shine.
Just last weekend I rolled the Z400 my wife calls her's. I left some surface scratches on the right rear fender. In order to avoid relentless nagging I thought I should fix it(before she had a chance to see it). I sanded with 200 Grit then 320 then wet sanded with 400 then 600 and finally 1500 grit. After this I buffed with a dry soft cotton rag. To restore the shine I applied several coats of "Plastic Renew". With the exception of 1 deep scratch good as new. I have used this on a couple ATV's I own. It works great if you take your time and complete all the sanding.
As odd as it may sound... I use Mop-n-glo
It's only a temporary fix, as I need to reapply a couple times / year... bit does shine nicely.
I've seen clearcoat, and it looks great! But then it comes off.... Ugh.
This is a great thread... lots of good info.
