Z 400 what is the Correct Way To Check The Oil Level? The Manual
Old Feb 3, 2004 | 10:12 PM
JOEYG's Avatar
Default Z 400 what is the Correct Way To Check The Oil Level? The Manual
Do I screw the stick in and then check it? or do i take it out wipe it off and then stick it in with out screwing it in? Also should i start it and let it run for a few minutes? then let it sit for a few and check it? my quad has not been run for a few weeks now. Thanks a lot
Old Feb 3, 2004 | 10:27 PM
WhiteZRacer's Avatar
Just wipe it off and then don't screw it in just sit it in the hole, and yes, I would let it idle for a few minutes, then let it sit for a few minutes, that is what it says in the manual.
Old Feb 3, 2004 | 10:29 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Definitely warm the engine up first! Oil will drain into the crank case when the bike sits for a while, and it will give you a bogus (low) reading. Like he said, don't screw the plug in, just dip it.
KimSJoh
14
Jul 18, 2015 07:20 PM
95wolv
Jul 17, 2015 08:13 PM
chammerbeck
Jul 17, 2015 08:06 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
