Differential lock options on 00 300 4x4?
Old Feb 13, 2004 | 12:39 PM
gutpile's Avatar
Default Differential lock options on 00 300 4x4?
This might be a stupid questions but.......Is it possible to use the differential lock in high or low range other than super low on the King quad 300's? If so what mods/parts do i need
thanks
Old Feb 13, 2004 | 12:48 PM
AlaskaBoy's Avatar
I never figured it out but I to want to hear the answer. I got alot of friends who still own the King Quad and the Quadrunner and would like to be able to pass this on.AlaskaBoy.
Old Feb 13, 2004 | 12:57 PM
AlaskaBoy's Avatar
Hey Gutpile, I was thinking I might have actually seen this after I said I had not and I was right. Go to the Suzuki page and look for a post by JJ54, it is titled KING QUAD REAR AXLE, scroll down to a reply by robnhouston and click on his tip page and he gives pictures and a description. Good luck if you make this work, that would of have made my King alot better if I could of used the locker in low. AlaskaBoy.
Old Feb 13, 2004 | 02:45 PM
Glenlivet's Avatar
I did that when I first bought my KQ. It work just fine. It is very hard to steer when in lock so the manufacturer puts that sliding pin business in there so you can only lock it in super low, so some idiot doesn't lock the front end and drive into a tree and then claim the bike made him do it cause it wouldn't steer! The old litigous society and the ways makers keep from being sued. We all pay in the cost of the quad for the added complexity of the shifter so jerks don't sue Suzuki.
Old Feb 13, 2004 | 06:03 PM
Harw's Avatar
That is easy to do. Remove the shifter *****. The the shifter panel. On the right side remove the nut and pull the right side shift leaver out of the way. Move the shifter leaver on the left and a pin will pop out on the right side. Remove the pin, put it back togather and you are done. About 20 min.
Old Feb 14, 2004 | 01:47 AM
gutpile's Avatar
thanks for your help!!
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
black_thunder
Sep 22, 2015 07:59 PM
rgjackson
Sep 17, 2015 11:21 AM
