engine paint removal
Old Feb 18, 2004 | 08:16 PM
thesb's Avatar
Default engine paint removal
I'm going to be stripping the paint off my cylinder and side covers. Does paint remover work ok on this stuff or am I stuck sanding it all off? Also, any polishing tips you guys have would be helpful.
Old Feb 18, 2004 | 08:54 PM
ZukZilla550's Avatar
I used a paint stripper and it worked good,just watch your skin and plastic and rubber part's,polishing,wow alot of work.I used a dremel,bech grinder with polishing wheel's,and a car buffer/polisher with a wool pad and a veriable speed drill with polishing wheel's.Sanding suck's but it has to be done to knock down the casting bump's on the jug,so you'll need sand paper.Polishing compound's are needed too,Black Emery compound for the rough stuff/heavy removal of scratches and imperfection's in the alum,Red Rouge for minor scratche's/imperfection's and White Rouge for your final Shine.Don't mix the compound's cuz they have different abrasive's in them,use seperate pad's and don't cake the compound on the pad,let the machine do the work and work the compound's in.Wear a dust mask cuz it's messy(black dust) don't want to breathe it.To keep your stuff shinny when done use Mother's alum.polish and an old sock or an old towel.Hope I helpep ya out.Good luck and take your time,Don't rush perfection,remember Bling,Bling
Old Feb 18, 2004 | 09:13 PM
lt250rthriller's Avatar
does the engine need to be off the bike before you use the paint stripper ?
Old Feb 18, 2004 | 09:20 PM
Well I did,it made it alot easier to get to certain spots and I didn't have to worry about the frame paint getting messed up.
Old Feb 18, 2004 | 09:50 PM
i want to get the paint off the frame as well but what about the exaust and whta paint can i use to paint the frame with out having to get it profesionally painted
Old Feb 18, 2004 | 11:34 PM
LT250Rodney's Avatar
Most exhaust paints that come in spray cans are crap. Do yourself a favor and just get them powdercoated. The stuff is amazing for toughness and heat resistance.
Old Feb 19, 2004 | 12:48 AM
JustinJones's Avatar
I used gasket remover to take the paint off of an LT250R jug I had laying around. worked pretty good. Got the job done.
Old Feb 19, 2004 | 01:36 AM
jstaguy24's Avatar
I stripped all the paint off of my frame and engine with paint remover in a spray can from the auto parts. Spray in on wait ten minutes blast it off with a pressure washer. very easy to do that way.
Old Feb 19, 2004 | 01:43 AM
Slacker1bob's Avatar
Brake cleaner works pretty good sometimes. Better than thinner
Sandman2.0
Jul 21, 2015 09:03 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
MNatv89
Jul 7, 2015 11:36 AM
Shifts
Jul 3, 2015 07:59 AM
