Proper Zilla Jetting?????
Old Mar 10, 2004 | 11:15 AM
shrtrdnck's Avatar
Default Proper Zilla Jetting?????
[img]i/expressions/face-icon-small-confused.gif[/img] I was wondering what the stock main jet size is for a 1987 quadzilla lt500r? IT has a 390 in it right now, but i think it may be too small , it is hard starting, i kick it over and it pops but doesnt start, it is like it isnt getting enough fuel, even when choked, but if i shut the ignition off and kick her over 4 or 5 times then turn it back on and kick it it will start and runn great. it idles perfect and everything runs out good, tons of power, but i think that jet is too lean, it had a 410 in it when i got it but someone told me that was too big, so we tried the 390 and it ran.
any help is apreciated
Dave M
Old Mar 10, 2004 | 11:48 AM
Slacker1bob's Avatar
Its probably your idle jet. The main jet won't effect starting
Old Mar 10, 2004 | 03:07 PM
shrtrdnck's Avatar
Thanks i'll rip it apart and check it out[img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 10, 2004 | 03:11 PM
evhwg's Avatar
at the same time check your needle setting to
Old Mar 10, 2004 | 03:22 PM
shrtrdnck's Avatar
what should the needle be st at?
Old Mar 11, 2004 | 09:24 AM
ZigZilla's Avatar
the 87 stock has a 420 Main jet. The needle is set to the 3rd slot from the bottom. Middle i do believe. But it all depend on your ride,temp and altitude.
The 88 Has a slightly different carb because of the changes to the machine
Also the 89-90 Carb Is slightly different also. Main jet sizes for these 88-90's were i think 390 (not sure).
Also turn the air screw in all the way and then back it out 1 1/2 turns
ReconBayou
Oct 31, 2022 05:37 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
