tuning a carb on z400-2004
Old Mar 27, 2004 | 03:17 AM
CrazyATVDad's Avatar
Default tuning a carb on z400-2004
Guys, I found alot of posts on how to re-jet a z400 - and some pictures that show all the important pieces. Anyway, I just recently purchased a WB E2 slip-on for my Z400 - and the WB installation said -- replace the Main jet with the enclose 165 jet - and move the air mixt screw 1/4 turn - richer - so i took that recommendation -but after looking and searching all over - i found out that the carb on this 04 model seems to be different than the 03 -- There is no screw to adjust air/fuel mixture - in its place is a brass cover with nothing... ??
so - i ended up putting a 147 - because it was choking with the 165 - and i couldnt adjust the air flow - why is that ???? How am I suppose to adjust the air flow - especially when you change the pipe - if the carb doesnt have an adjustment..
anyone find this prob. Anyone out there with an 04 model - that has recently re-jetted the bike - please let me know how I can fix this. Id like to put the 160 jet back on and adjust it around that.
Question1 --- what is your pipe/jetting size/ air adjustments that you made.
Question2 --- anyone with 04 model adjust the airflow ??? if so - please let me know how.
Im lost.
THANKS EVERYONE.
Old Mar 27, 2004 | 04:00 PM
chazekxt's Avatar
i also have a 04 u have to drill out the little plug on the bottom of the carb. they are set at 2 1/4 turns.
Old Apr 5, 2004 | 12:20 AM
z400fmf's Avatar
there is a cover over the air screw. u need to pop it out and adjust it
Old Apr 5, 2004 | 05:12 AM
KFXCarnage's Avatar
Does that cover just pop off and no damage?
Old Apr 5, 2004 | 01:07 PM
bvstone's Avatar
The easiest way to remove it is drill a small hole in it.. if that does't get it out, then put a screw into the hole and it will come out pretty easy.
Just make sure you're drilling the correct brass plug, because there are two that look similar under there.
Old Apr 5, 2004 | 01:21 PM
Mars's Avatar
WB R-4. No lid or snorkle. Noss intake. 165 main. Nothing else changed.
A 165 main may be a bit ritch depending on you elevaton. You did remove the lid after installing the 165 right?
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
black_thunder
Jul 26, 2015 09:23 PM
Aitch
Jul 21, 2015 09:40 PM
maxjung
Jul 13, 2015 05:11 PM
