clutch question!
Old Jul 17, 2000 | 01:23 AM
QuadDude05's Avatar
ok, i gotta 87 230 quadsport bada$$. but lately when i am riding the rpms will be steady and increasing when pushing in the throttle (like normal) then all of a sudden and kinda stops and goes slower and the rpms shootup in the air, is this my clutch? or throttle?
what do i need to buy?
Old Jul 17, 2000 | 05:20 AM
ecorman1's Avatar
I'm not sure I understand you. Did you just buy this machine from someone or is it something you've had all along and this problem just arrived? Does the problem come and go or is it always there and does it happen in any particular gear? If you can be a little more specific, some one out there will probablly know your problem.
Good luck QuadDude.
Chuck, Suzuki KQ 300, GPS & lunch...
Old Jul 17, 2000 | 06:36 AM
Tree Farmer's Avatar
Sounds like either the clutch is slipping (or you've found the "extra neutral" in the gearbox).
First, I'd check the clutch for proper engagement adjustment (I assume you have a service manual).
If you can't adjust out this problem, pull the case and check clutch discs and springs. Does your ATV have a manual or automatic clutch? If automatic, you need to check out the primary (centrifugal) clutch also. Good luck!
Tree Farmer
Old Jul 17, 2000 | 10:30 AM
86Honda200SX's Avatar
No his quad has a manual clutch.
Old Jul 17, 2000 | 12:13 PM
jakeh's Avatar
sounds like you need a new clutch to me .
or it could be out of adjustment!!
good luck
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
