changing fuel/oil ratio
Old Mar 29, 2004 | 03:22 PM
needaR's Avatar
Default changing fuel/oil ratio
the guy that had this quad before me ran 20:1.would it be ok if i run a full synthetic(belray H-1R) at 32:1 or 40:1?would i have to rejet or anything?
Old Mar 29, 2004 | 08:46 PM
Slacker1bob's Avatar
You definately want to run at least 32:1. 20:1 is a waste. You probably have to rejet since your letting more fuel in. Just check your plug. It tells you what it needs.
Old Mar 30, 2004 | 10:44 AM
Duneaddict's Avatar
Slacker is right... You will definitely need to rejet, as changing the mixture really changes jetting. IMHO MC-1 is a decent oil, but not the best out there... especially since there are some really really good synthetics now.
20:1 is a waste, and was intended to be used with the old dino oils of yesteryear.. technology has evolved.
Good luck!
Old Mar 30, 2004 | 02:16 PM
needaR's Avatar
which jet will i need to change? i have no clue what jets are in it right now.how can i tell?does it say the sizes on the jets?anyone have a carb diagram for the keihin PJ series carb?thanks
Old Mar 30, 2004 | 03:32 PM
needaR's Avatar
anybody have any idea of what jets i should start with?i live in ohio,fmf goldseries pipe,uni silencer and filter,no airbox lid, and a keihin pj carb
how many turns out on the air screw should it be at?i thought it was the idle and accadently messed with it.
going to switch from 20:1 to 32:1 full synthetic 2 stroke oil.thanks
Old Mar 30, 2004 | 03:39 PM
Your going to just ahve to test things. The air screw will be in the 1.5-2 turns out range. Run the quad with whatever jet you have, youll just run a little rich, and then check your plug.
Old Mar 30, 2004 | 03:48 PM
needaR's Avatar
ok.which jets do i change?main,pilot,etc?do i go up on the main to lean it out?iv never jetted a carb
Old Mar 30, 2004 | 04:37 PM
sam250's Avatar
Everything you need to know about jetting is right here.
Old Mar 30, 2004 | 08:52 PM
If you have never jetted, I suggest finding a friend that can and show you how.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Jackg17
Sep 26, 2015 09:30 PM
rockinkgin
Sep 25, 2015 01:52 PM
