hard to start lt250r
Old Apr 12, 2004 | 04:21 PM
madhatter801's Avatar
Default hard to start lt250r
After it has sat for a while, overnight or so, and i go to start it up it won't. I have spark, but i don't think i am getting any fuel. If i poor a little gas down the cylinder it seems to start right up, and after i get it started and warmed up it will start good the rest of the day. But, as soon as it sits for a little while i have to go through the whole deal again.
Old Apr 12, 2004 | 04:38 PM
I forgot to mention that it also won't idle, i always have to hold the throtle slightly open or it will slow way down and die, but it runs really well otherwise.
Old Apr 12, 2004 | 08:29 PM
badchad's Avatar
It sounds like you already have your problem figured out. If you're not getting fuel, she won't run! First, be sure you have fuel in your quad......sounds silly, but I bet all of us have run low and not noticed it, second, turn you gas petcock off and remove your fuel line from your carb and get something to catch fuel in. Turn the gas on and see if you have fuel flowing through the line. If you have fuel flowing through the line then there's a problem in the carb. Take it off and clean out the jets and check your floats, also be sure to blow through all the vent lines from your carb to make sure they're not plugged up or pinched anywhere.
Old Apr 12, 2004 | 09:51 PM
Kimusaby's Avatar
How's your jetting? I had a problem starting my quad until I richened the needle jet. Now it fires up like a charm.
Old Apr 14, 2004 | 10:44 AM
CapnMorgan's Avatar
This is a problem with Mikuni Carbs. They suck. Get a kehin air stryker. I had three Suzukis and they all did it. The problem is in the jetting. rebuild the carb and then rejet. The hard start and no idle is caused by the pilot jet being cloged or to small. Also make sure the air screw is not closed all the way, it should be opened about 2 turns. here is a link to jetting instructions http://www.ohv.8m.com/
Hope it helps.
Almost forgot- Check the crank seal on the flywheel side. Remove the stator cover and if its got oil or carbon build up inside the seal is bad and could cause a lean condition.
Old Apr 14, 2004 | 12:22 PM
badchad's Avatar
CapnMorgan, I have to agree with you 100% on the carb issue. I'm running the same one you have. Not only that, but I have it out for the stock swingarms too.....junk just like the stock carb!
MikeyBoyesq
Nov 27, 2020 02:44 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Ty Speece
Jul 2, 2015 04:59 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
