Running out of compression?
Old Apr 17, 2004 | 12:41 AM
didididididi's Avatar
Default Running out of compression?
Yeah hi you guys doing. I dont know, but when i use my hand to pull the started down, i could feel the compression (burping sound). MY question is when i could use my hand the push the kick start all the way down, am i running out of compression? Or is it normal? i thought it shhould be hard to kick?(not impossible though) Its a all stock 85 lt 250r,past owner says its "all stock, never been touched." If i dont do anything about my compression, would anything bad happen? Im a beginner into riding 2 strokes.
What 2 cycle oil you guys recommend.
Old Apr 17, 2004 | 12:57 AM
needaR's Avatar
i just siezed mine up.but before i did you couldnt push the kicker down with your hand.id get ur compresssion checked.if its low.replace the rings and get a hone.get a overbore piston and bore if needed.is it hard to start?mine is a 89 w/powervalve so it might be different
Old Apr 17, 2004 | 10:20 AM
CapnMorgan's Avatar
I have an 88 with 194lbs of compression(really good) and I can push the kicker down by hand but its hard when it hits the compression spots. does yours just go down and make noise or can you feel the compression in the kicker.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Mphillips
Jul 2, 2015 07:20 PM
joshuafromny
Jun 22, 2015 05:30 PM
scaldwellk
Jun 19, 2015 05:08 PM
generalpops
Jun 5, 2015 08:23 PM
