vinson auto tranny problem
Old May 4, 2004 | 10:15 PM
macgiver's Avatar
Default vinson auto tranny problem
the auto tranny on my buds vinson is locked up. the shifter will go into park and reverse, or so the display reads. but thats it. tride moving the linkage on the side of the engine, but that didnt help.the quad will not move. any ideas. its an 02 with 600 miles on it
Old May 5, 2004 | 06:10 AM
macgiver's Avatar
BUMP
Old May 5, 2004 | 10:12 PM
macgiver's Avatar
BUMP BUMP
Old May 6, 2004 | 03:24 AM
Snug's Avatar
2002 had a problem with the autos. They have a shift kit that needs to be installed. The problem is; it takes 11 hrs to do(per dealer) and at $74 an hr....OUCH!! I am having the same problem on my 02. the 03 works great, but they installed the kit on them. Try and find a dealer that will work with you on getting Suzuki to pay for it. That's what I am in the process of doing. Goood luck!
Doug
Old May 6, 2004 | 05:52 AM
macgiver's Avatar
i am aware of the shifter problem, but thats not it. the transmision is locked up. quad wont move in forward or reverse. if you give it gas you can hear the belt start to slip. something went inside the trans.
Old May 13, 2004 | 12:40 AM
mikviking's Avatar
I bought a 4 year warranty with my vinson, will they cover my shifter problem also. I would think so I'm going to check in the morning. Brand new to this forum. Love my vinson.
Old May 16, 2004 | 11:55 PM
BlueOne's Avatar
Take the cover off the side and check the belt really good,it might not look to bad ,but if any bad ribs ,then that could be part of the problem,then check the clutch bearing, it also might be bad and that piece is not cheap.the belt also is not cheap. something to think about.good luck
Old May 17, 2004 | 06:03 AM
macgiver's Avatar
i dont see how a worn belt or cluch bearing could lock up the tranny
Old May 17, 2004 | 09:23 PM
BlueOne's Avatar
I had the same thing happen to me in the middle of a river and had to be pulled bad home,was not fun,but the belt had worn somwhat and a bearing went bad,hope it's not the same problem, good luck
lightninboy
May 16, 2021 09:52 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
TheHood
Jul 26, 2015 09:51 AM
hondarider1234
Jul 21, 2015 11:53 PM
Unzzy66
Jul 11, 2015 10:01 PM
