Ball Joints for LT250r...are there any automotive joints that will work?
Old May 5, 2004 | 05:26 PM
Tankota's Avatar
Default Ball Joints for LT250r...are there any automotive joints that will work?
Through a search I found that on some of the honda 250r guys were using a ball joint off of a ford courier or something like that. said it cost half as much but was the same joint.
Is there an equivalent thing for the LT250R?
Old May 5, 2004 | 10:28 PM
LT250Rodney's Avatar
Take one to an auto parts store and ask. Its more than likely the same size as a tie rod end on a car so maybe they can do something for ya. I doubt itll be th EXACT same but you can make one work if its close.
Old May 6, 2004 | 10:41 AM
emmerth's Avatar
I'm givin this a bump because I am curious as well.
Also, does anybody have any suggestions for new/aftermarket ball joints for the stock a-arms?
Old May 10, 2004 | 11:55 AM
emmerth's Avatar
ttt
Old May 10, 2004 | 02:06 PM
Tankota's Avatar
I'll be taking them off later this month to replace and I'll do some looking around to find out if any industrial/automotive ones will work...I'll let you know if I find anything.
Was hoping someone else had figured it out...so back to the top.
Old May 13, 2004 | 05:07 PM
Tankota's Avatar
No luck so far. Looks like it will be $$$factory parts.
I removed the balljoint and took all the necessary measurements with a micrometer and scoured the internet for a couple days. Appears that no one makes one exactly like it (the shoulder presents a problem as does the indentation/retainer groove on the vertical part of the joint that goes into the knuckle). I could probably modify one by welding on shoulders and grinding in the groove but that is alot of work for something that may not set my camber exactly where it was stock.
Also, all the aftermarket A-arm manufacturers I have seen say you have to use the stock lower balljoints (they dont' sell any replacements)
BUMMER!
PS IF anyone figures out another option post it here to let us know.
Old May 13, 2004 | 05:15 PM
aksafari's Avatar
Balljoints? Who needs Balljoints? They're overrated anyway.
Peter_
Jul 18, 2015 07:06 AM
musselmark
Jul 17, 2015 02:40 PM
toonces
Jul 11, 2015 12:01 PM
Jul 7, 2015 11:00 PM
bikedad3
Jul 2, 2015 02:15 AM
