how do u measure toe in for the front wheels?
Old May 7, 2004 | 10:13 PM
800screws's Avatar
Default how do u measure toe in for the front wheels?
how do u do it??
Old May 7, 2004 | 10:56 PM
CapnMorgan's Avatar
Toe in is when your front wheels are closer together at the front
Toe out is when there closer together at the back.
You just measure it with a tape measure. Your front wheels should have about 5-10mm toe in.
Make sure your handle bars are straight then measure from the rim to a common spot of the frame on both sides. The measurements should be the same. This will verify proper alignment.Then adjust your front wheels so that the front is 5-10mm closer together than the back(of the front wheels).
TLC
Jul 25, 2015 02:24 AM
Jul 21, 2015 03:03 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
tporath
Jul 11, 2015 12:31 PM
