lt 500 ignition problem????
Old May 7, 2004 | 10:58 PM
POLARISFREAK's Avatar
Default lt 500 ignition problem????
This thing is very hard to start, go wide open with and it sputters, has need reeds, new 39 pwk carb, jetted down to a 150 main and still was stumbling badly on the top end. The plug is reading very rich anyone out there had ignition problems with the lt 500?
Old May 7, 2004 | 11:09 PM
CapnMorgan's Avatar
WOW! 150 on a 39 on a zilla and still rich. are you missing the needle lol.
Is it smokin alot.
Old May 7, 2004 | 11:14 PM
Doesn't seem to be, but it was running fine, then all of a sudden it just wouldn't rev, acted like it was rich. Started fouling out plugs, guess I should check compression first, look at the ignition switch.
Old May 7, 2004 | 11:34 PM
CapnMorgan's Avatar
Actually I was joking about the needle but you may want to check if the clip came off or somthing.
I've seen alot of suzukis with ignition probs tho. on the 250s the wires coming out of the stator cover get it when the chain pops. I don't know if the 500 is the same. Also I had a problem with my factory kill switch. I took it apart and cleaned it and greased it up with electrical grease and the problem went away but now every time I wash it and get on it while its still wet it'll shock me if I touch it(real bad, like the spark plug wire).
my problem with the kill switch caused total spark loss. yours only does it at high RPM so could be coil/stator. if you call the dealer they'll give you the specs to test everything but CDI with a multimeter.
hope this helps, I just had 7months of downtime and know what it's like.
Old May 7, 2004 | 11:44 PM
Thanks for the help, I'll give them a call!
Old May 8, 2004 | 11:33 AM
sam250's Avatar
When my crank seals were going out, it ran as if it was rich. I guess it was only passing a very small amount of oil.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
greg74
Sep 10, 2019 03:03 PM
Unzzy66
Jul 11, 2015 10:01 PM
Albertascramblerx
Jul 8, 2015 11:56 PM
