pro circuit slip on on Z question
Old May 11, 2004 | 05:37 PM
Csquared's Avatar
Default pro circuit slip on on Z question
will i gain any power if i put a T4 slip on on a stock Z400? do i need to rejet?
Old May 11, 2004 | 06:51 PM
wrench12123's Avatar
yes you will gain power and i recommend that you get it too.
Old May 11, 2004 | 06:52 PM
jet it too, i didnt mean to type get it too
Old May 11, 2004 | 09:05 PM
chazekxt's Avatar
go with hmf
Old May 12, 2004 | 02:17 AM
outNfront's Avatar
Yes, you will gain power. No you don't need to re-jet. I haven't seen or heard the slip on but the full system looks and sounds great. Most important it performs well!
Old May 12, 2004 | 03:27 PM
03hmfz's Avatar
Yes you do need to rejet. any mods you do the increase performance are noticed after you fine tune your jetting.
Old May 12, 2004 | 09:46 PM
z838mx's Avatar
lol most slip on will go on with out rejet. some may not. you need to put the pipe on before saying it will or wont need it.
Old May 12, 2004 | 10:01 PM
Ball's Avatar
IMO there would be absolutely no reason to change the exhaust if you did not need to rejet. The point is to get more air so that you can get more gas. If you open up the exhaust so that more air can go through you will not make any gains until you put more gas through. You get optimal performance at "x" air + "y" fuel= "z" HP. If you"x+2" air, You must "y+2" fuel, then that will=HP+2.
Old May 12, 2004 | 10:23 PM
z838mx's Avatar
makes sence in a way but look its not a big improvement to put a slip on on your machine. people thing its noticable power it is more power and it sounds different so therefor you feel like you added 100 hp on a machine that one has mid 20s for hp stock. Reality is that a slipon pipe on the dyno ive seen it with my own eyes at the dealership That I work at they just give such a small improvement that most times they dont need to be jetted the carb can be adjusted also to get it right if not. The air/ fuel meters tell us what is going on and usually they dont need it but sometimes they will. alot of factors in jetting.
1ArmBandit
55
Oct 14, 2015 09:03 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
Brandon400
Sep 7, 2015 12:20 PM
Brandon400
Sep 5, 2015 08:44 PM
toonces
Sep 5, 2015 01:14 PM
