z250 or lakota
Old May 11, 2004 | 11:34 PM
tmaxx's Avatar
Default z250 or lakota
Not sure which one to buy, any suggestions. I would be riding mostly trails and open fields.
Old May 11, 2004 | 11:45 PM
LTZlightning's Avatar
hmmm. hard choice.... NEITHER!!!! get a 400 they are so much better. If 400 is too big get a warrior or raptor 350 or if that is too big 300ex.. nothing less... how big a boy are ya?
Old May 11, 2004 | 11:59 PM
tmaxx's Avatar
im around 5'7 140
Old May 12, 2004 | 07:48 AM
MBrooks420's Avatar
It all depends on what you are looking for. Some people don't need a 400. If you want a sporty auto clutch bike the z-250 and Lakota are both good choices. The Lakota has lots of torque and power down low, but is a little on the heavy side. The Z-250 is lighter, probably handles a bit better, but is shaft drive, so you are stuck with the factory gearing forever.
Old May 12, 2004 | 05:36 PM
tmaxx's Avatar
i was also looking at a mojave. is there any big difference in power (DOHC). Also how does liquid cool compare to air cool.
Old May 12, 2004 | 05:39 PM
tmaxx's Avatar
i forgot, hows the top end on a mojave....top speed?
Old May 12, 2004 | 05:42 PM
z250freak's Avatar
get the mojave, its an all aroumd better quad.
Old May 12, 2004 | 06:04 PM
MBrooks420's Avatar
If you don't mind the clutch the Mojave is the sportiest, and has the most mods available. Liquid cooling is almost always better than free air. The Mojave probably goes about 63.
Old May 13, 2004 | 06:19 PM
no!!! if clutch isn't a problem get the 300ex way better that all the 250's
Old May 13, 2004 | 10:54 PM
mahnster's Avatar
I would go for the mojave. It is a great little quad. It will go around 55-57 mph. It is as fast as a 300ex but the mojave has liquid cooling which is a major advantage. There is also quite a bit of aftermarket for the mojave if you know where to look. If you cant handle a clutch go for a z250. Just puttin my .02 in.
kwackermann
Jun 24, 2015 10:18 AM
KawasakiLakota
Aug 23, 2000 11:57 PM
blazer1969
Aug 23, 2000 02:45 PM
shockwave
Aug 20, 2000 07:57 AM
cstark
Oct 15, 1999 01:45 PM
