88 suzuki quadsport
Old May 17, 2004 | 03:19 PM
sportnquad's Avatar
Default 88 suzuki quadsport
i need help adjusting a chain what bolts do i loosen it adjust it? I have a clymner manual but,it doesn't
show the setup i have.
thanks
Old May 17, 2004 | 04:14 PM
LEP7MM's Avatar
There is a pivot bolt at the top of the swingarm. Then at the bottom of the swingarm, there should be 2 shorter bolts that tighten the axle in place, loosen these too. There should also be two small bolts that point straight out the back which pull the axle backwards to tighten the chain. Use these to pull the axle back. Make sure you leave about 1/2-5/8" of up and down movement in the chain (I think that was the recommended play). Also, make sure you turn each of the smaller screws the same amount so your axle stays square with the machine. Re-tighten everything.
Old May 17, 2004 | 05:32 PM
MBrooks420's Avatar
The 230 is supposed to have 1.5-1.8 inches of chain travel at the center. Any less and you will at best snap a chain.
Old May 18, 2004 | 11:33 PM
Specialyst's Avatar
there are 2 different swingarm types which one do you have?
Old May 19, 2004 | 07:38 AM
MBrooks420's Avatar
Being an 88 he would have the oval style carrier, not the round style used in 85-86.
Old May 19, 2004 | 11:34 AM
sportnquad's Avatar
yes it is ovall
Valder
Nov 28, 2020 07:38 AM
fd24
Jan 16, 2019 08:59 AM
VABrute
Jan 6, 2016 07:39 PM
merryman
Sep 19, 2015 03:15 AM
Sep 1, 2015 11:59 PM
