carb fits horribly?
Old May 18, 2004 | 05:25 PM
needaR's Avatar
Default carb fits horribly?
i have a kehin PJ34 carb and it fits horribly between the stock bootsdo any of your guys carbs not fit good?i think it would be much better if the intake boot came straight out of the reed assembly rather than down and to the right.it takes me every bit of a half hour to get it off and back on without doing anything inbetween.
Old May 18, 2004 | 05:33 PM
Tankota's Avatar
I've had an intake problem with the quadracer i just got. The intake on it curved down and to the right like you described. However, using the stock airbox and tube put ALOT of pressure on this intake boot and eventually cracked it about half way around. The boot had a really big "mouth" on it so the 38mm a/s carb fit into it easily. LRD told me it probably came off of a '92 RM250 and the previous owner said he thought it might be off of a LT500. Not sure which one is correct though.
Before I knew it wasn't stock I went and bought a stock one and it only bent down....not to the side though. Also the mouth was much smaller. It appears some guys are able to get them to fit. I don't have experience with this quad much so I just returned it and bought a rad valve from LRD which they said they modify some to flow better and it is supposed to solve all my fitment problems. We'll see how it works out.
Old May 18, 2004 | 06:37 PM
needaR's Avatar
so the intake boot on my quad may bee one off a RM?how much was a stock one?
Old May 18, 2004 | 07:06 PM
Tankota's Avatar
That is what I was told by LRD...no way for me to confirm it without seeing a rm250 boot.
The stock LT250 one i returned was about $50. The rad valve was more than double that.
Old May 18, 2004 | 07:32 PM
needaR's Avatar
ok.can someone please look to see if their intake boot goes down and to the right or strait down?
Old May 18, 2004 | 11:39 PM
1987LT250's Avatar
it shouldnt goto right or left
Old May 19, 2004 | 02:17 PM
Tankota's Avatar
Correct. I was told the motorcycle (RM250) one goes to the right because the rear shock on the bike is closer to the engine so the intake has to "turn" out quicker to miss it.
Old May 19, 2004 | 09:23 PM
needaR's Avatar
anybody have a stock boot they would be willing to sell me for cheap that they arent using?it has to be cheap because all of my money goes straight to my sister to pay the quad off.like you people with rad,ram,whatever do you still have your stock ones?thanks.i got ur PM 1987LT250 but it wouldnt let me reply.im interested in the boot.how much you want?
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
micheleLeigh
Jul 12, 2015 02:50 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
