LTZ 450
Old Jun 11, 2004 | 10:11 PM
  #31
Crashman44b's Avatar
Default LTZ 450
Originally posted by: KFXCarnage
Does that apply to the '04 z/kfx/dvx too?Gussets that is.Mines still ok but I havent jumped the Grand Canyon yet eather hehe.
You should be ok. I wouldn't worry about it until in breaks. There was alot of problems with the frames on the ltz400's early(mid 2002) in the production runs, but from what I 've heard they got them fixed.
Old Jun 12, 2004 | 12:12 AM
  #32
Sandgod's Avatar
Default LTZ 450
I found the new Z450. It will be a 450 instead of the 432cc...
<TABLE width=417 border=0>
<TR bgColor=#cccccc>
<TD class=body1 width=131><B><FONT color=#000000>Engine</FONT></B></TD>
<TD class=body1 width=276>Four-stroke single</TD></TR>
<TR bgColor=#ffffff>
<TD class=body1 width=131><B><FONT color=#000000>Displacement </FONT></B></TD>
<TD class=body1 width=276>432cc </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Bore & Stroke </FONT></B></TD>
<TD class=body1 width=276>95mm x 61mm </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Compression Ratio </FONT></B></TD>
<TD class=body1 width=276>12.5:1 </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Valve Train </FONT></B></TD>
<TD class=body1 width=276>DOHC, 4-valve </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Fuel System </FONT></B></TD>
<TD class=body1 width=276>EFI, 11,600 RPM soft rev Limiter</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Cooling System </FONT></B></TD>
<TD class=body1 width=276>Liquid-cooled</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Ignition System</FONT></B></TD>
<TD class=body1 width=276>Constant-energy inductive coil </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Starting System </FONT></B></TD>
<TD class=body1 width=276>Electric Start</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Compression Release</FONT></B></TD>
<TD class=body1 width=276>Automatic</TD></TR>
<TD class=body1 width=131><B>Lubrication System</B></TD>
<TD class=body1 width=276>Dry Sump</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Clutch Type</FONT></B></TD>
<TD class=body1 width=276>Manual, hydraulic</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Transmission</FONT></B></TD>
<TD class=body1 width=276>5-speed cassette, no reverse</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Drive</FONT></B></TD>
<TD class=body1 width=276>2WD/520 Chain</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Frame Type </FONT></B></TD>
<TD class=body1 width=276>Aluminum, twin spar, perimeter</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Length</FONT></B></TD>
<TD class=body1 width=276>73.5" </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Width </FONT></B></TD>
<TD class=body1 width=276>50.0" </TD></TR>
<TD class=body1 width=131><B>Wheelbase</B></TD>
<TD class=body1 width=276>50.0"</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Turning Radius</FONT></B></TD>
<TD width=276><FONT face="Verdana, Arial, Helvetica, sans-serif" color=#000000 size=1>8.7'</FONT></TD></TR>
<TD class=body1 width=131><B>Seat Height</B></TD>
<TD class=body1 width=276>32.25"</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Ground Clearance </FONT></B></TD>
<TD class=body1 width=276>4.25"</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Dry Weight </FONT></B></TD>
<TD class=body1 width=276>375 pounds (competition weight) </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Front Suspension </FONT></B></TD>
<TD class=body1 width=276>11" travel </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Rear Suspension </FONT></B></TD>
<TD class=body1 width=276>10" travel </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Front Tire </FONT></B></TD>
<TD class=body1 width=276>20 x 6-10</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Rear Tire </FONT></B></TD>
<TD class=body1 width=276>18 x 11-8</TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Front Brake </FONT></B></TD>
<TD class=body1 width=276>Hydraulic, dual "wave" disc w/parking </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Rear Brake </FONT></B></TD>
<TD class=body1 width=276>Hydraulic, single "wave" disc </TD></TR>
<TD class=body1 width=131><B><FONT color=#000000>Fuel Capacity </FONT></B></TD>
<TD class=body1 width=276>3.2 gallons </TD></TR></TABLE>
Old Jun 12, 2004 | 01:07 AM
  #33
13inc's Avatar
Default LTZ 450
I've heard that also but, I can't see anything different on the newer chassis
Old Jun 12, 2004 | 02:09 AM
  #34
MURDR's Avatar
Default LTZ 450
what do you mean you found the z-450 start talken!
Old Jun 12, 2004 | 04:09 AM
  #35
LT250RSuperstar's Avatar
Default LTZ 450
Sandgod it looks like you posted the specs for the Cannondale Moto.....I, I mean WE, want the info on the Z450....
Old Jun 13, 2004 | 04:31 PM
  #36
Sandgod's Avatar
Default LTZ 450
I did.. Nobody was complaining of the specs though and they sure would be impressive if that was the Z450 spec sheet... I was just joshin ya... No harm meant..
