LT 230 carb ?
Old May 22, 2004 | 01:12 PM
ThrashAndCrash's Avatar
Default LT 230 carb ?
There is a "starter limiter" on the side of my carb. What is it for? What is the propper way to use it in congunction with the choke?
Also on the pilot screw... What is the propper order all this goes in the carb? (book sucks) I have it as follows:
pilot screw--spring--o-ring--little metal washer--carb......do I have the o-ring and the metal washer in the propper order?
When I took it apart all that was there was the pilot screw! (it did not run)
Old May 22, 2004 | 02:31 PM
MBrooks420's Avatar
The starter limiter is for cold weather starting. Below 40 degrees I think. According the the illistration in my factory service manual, the o ring, and metal washer apear to be backwards.
Old May 22, 2004 | 03:07 PM
Thank you I will try that, the picture in my Clymer is of no help at all
Old May 22, 2004 | 03:11 PM
Specialyst's Avatar
hey it says you need an axle carrier any luck cuz i have a spare one from my rolling 230
Old May 22, 2004 | 03:30 PM
MBrooks420's Avatar
I just picked up a used one, so I should change the signature. Thanks for the offer though.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
