38mm carb for 36, any takers?
Originally posted by: 1BAD250R
Hey AKSAFARI, I just bought a 38mm Flat Side Keihin carb for my '86 TRX250R. It's 30 over with a CT pipe Pyramid Reed Force Valves and I've got the airbox lid removed. You sound like a man who knows jetting so what jet would be a good place to start to fine tune my bike? Thanks!
Hey, thanks for the compliment, but I have NO IDEA. Take the jet that's in it, then I'd go 2 or 3 jets larger to start out. Make sure your needle clip is in the center slot. Once you get close with your jet, move your needle up/down one tick to fine tune.
I'd just try and start out rich, then work toward lean, rather than the other way around. Lean is dangerous, rich is just annoying.
#16
#17
You wont have a problem running a 38mm carb on the LT. It will work good once you get it jetted right. You might want to start a new topic and ask what jetting you should use. Once you get it dialed in the LT will scream and will work even better if you do some work to your motor.
#19
1badr- Most 38mm carbs come with a main of about 170. Thats to fat for your bike. Put a 162 in it and go down from there.
anyways a 38mm is not to big for a stock 250. you will loose some bottom end though, but it should run alot smoother and rev higher/quicker with the 38mm.
#20
thanks guy, thats really what i was asking, if it would work, and the if its lean, go bigger, if its rich, go smaller, and i just got one more question, which jet would i be chaniging, i sound stupid asking this, but there are a number of jets i could change.
