2-Stroke Notice!
Old Jun 25, 2004 | 11:18 AM
LT250s's Avatar
Default 2-Stroke Notice!
I was looking stuff up on the interenet, and came upon this.. ( http://www.offroadhaven.com/powervalve.htm) It is interesting because they say , " Few QuadRacer owners seem to be aware of the fact that Suzuki provides a drain plug for the SAEC chamber. This drain plug should be removed periodically to allow any accumulated oil or water to be removed." Good Idea, eh? That specific paragraph is located where the two pictures are.
Old Jun 25, 2004 | 01:01 PM
LT2Fiddy's Avatar
so where is this drain plug located??
Old Jun 25, 2004 | 01:13 PM
sam250's Avatar
Just yesterday I found an old post on another forum that mentions this drain plug. It said that you should blast a little carb cleaner in there once a year to clean it out.
How else can the powervalve be cleaned without pulling off the jug? I haven't checked to see if it's actuating through the little window, but I'd like to know how to clean it if it's not.
Old Jun 25, 2004 | 01:14 PM
LT250s's Avatar
i actually think it was only on the 500cc models. (quadzilla). But if it is on the 250's also, then it would be right in the front of the engine.
Old Jun 25, 2004 | 01:42 PM
LT250s's Avatar
isnt the power valve actually the exhaust valve? .. couldnt you just take the spark plug off and put some carb cleaner in there?
Old Jun 25, 2004 | 01:52 PM
LT2Fiddy's Avatar
umm...2 strokes dont have exhaust valves like your 4 stroker does. Power valves just make the exhaust port height smaller or larger for different powerbands.
Old Jun 25, 2004 | 02:15 PM
sam250's Avatar
Alot of later powervalves work like that but the SAEC system on the LT's works a little differently. At low rpm, it allows the exhaust to flow into a chamber in the engine case as well as the pipe (Click the link on the first post and it's the blue area on the 2nd picture) effectively making the exhaust more like a 'low end pipe'.
wrencher82
Sep 30, 2015 04:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
