why would pressure be building behind the stator cover?
Old 06-28-2004, 07:37 AM
800screws's Avatar
Default why would pressure be building behind the stator cover?
i have blown the 2nd gasket from the stator cover on my 92 lt250r? any reason why pressure would be building up in there? the crank and balancer are both tight.
Old 06-28-2004, 02:56 PM
hondabuster's Avatar
Crank seals shot?
Old 06-28-2004, 03:17 PM
gogoquadzilla's Avatar
do you have any oil leakage in there with the stator?
Old 06-28-2004, 06:06 PM
800screws's Avatar
no, it's clean.
Old 06-28-2004, 06:39 PM
rooster123's Avatar
your crank seal is no good
Old 06-28-2004, 06:43 PM
wouldnt there be a little gear oil leaking in there if it was bad?
Old 06-28-2004, 07:43 PM
TomM's Avatar
Nope. Onyl fuel and air. The gear oil is confined to the tranny.
Old 06-28-2004, 08:21 PM
800screws's Avatar
is it a job to replace the seals? splitting cases or anything?
Old 06-28-2004, 11:24 PM
LT250Rodney's Avatar
You SHOULD split the cases, but it can be done without.
Just stick a screw into the old seal (not too far!!) and use vise grips on the screw to yank it outta there. Then press the new one in and viola!
Old 06-29-2004, 07:44 AM
800screws's Avatar
i don't want to sound lazy, but i will check my repair manual today, but where is the seal? do i take the stator cover off and where is it from there? anyone know if those big gasket kits off of ebay contain the crank seal?
fordfaithful21
12-07-2015 05:52 PM
NRA+1
1) Engine problems..
10
09-20-2015 08:47 PM
carid
09-14-2015 03:40 PM
zPuls3
09-12-2015 08:54 AM
jeff mc
Dunes and Dune Machines
09-03-2015 07:47 PM
Quick Reply: why would pressure be building behind the stator cover?
