Adjusting valves sucks!
Old Jul 5, 2004 | 03:01 AM
EAB's Avatar
EAB
Default Adjusting valves sucks!
What are valves ?[img]i/expressions/face-icon-small-happy.gif[/img] ( a little 2-stroke humor......aw never mind)
Old Jul 5, 2004 | 03:33 AM
aksafari's Avatar
Originally posted by: LimpingLizard
My third adjustment was closer.... I'm at .229 on the exhaust and .080 on the intake. It is fine at full throttle, but backfiring a little through the airbox when you barely hold the throttle in now, so I'm guessing I need to come down closer to .05 on the intake side?
Dude, I sure hope you just didn't put the decimal in the right place, because your valves should have a clearance measured in THOUSANTHS, not TENTHS. I don't even know if it's possible to adjust the exhaust valves to have .229 INCHES of clearance. That's almost a 1/4 inch!
Or are you talking mm? Maybe that's it... *whew* got a little worried there.
Old Jul 5, 2004 | 10:06 AM
Vinson581's Avatar
dbuz, can you pull the wheels off the ground now, and get in a wheelie
thanks mje, i am going to try this, i think, are there any signs to look for when listening to the motor besides tapping, i seems pretty smooth, is it really neccisary.
v581
Old Jul 5, 2004 | 06:58 PM
MJE's Avatar
MJE
well somewhere on this forum are the values that the bike should be according to the factory hit search under vinson valves and you'll find it...or just valves...
anyways you'll need to get a feeler gauge from sears (one that gets really small)...
at first id say feel your valves before you loosen the bolts...however most people including myself when i did this bike the first time sat there going DUH wheres the valve stem etc etc...
thats why i suggested loosening them and then readjusting them. They are most likely off to the highest clearance possible if you have 1600 miles or whatever you said you have. Just look to make sure that your tappets (the little metal threaded rods that the tiny nut goes onto are in good shape (at the bottoms of them)
reminder the tappets only come out by twisting downwards so dont try to take em out (you shouldnt need to plus you might force it against the thread and frig em up)
But first feel underneath those tappets with your gauge and if its ok then dont worry about it...but if it is loose then pull those nuts like i said.
As long as you tighten those tiny nuts you shouldnt have any tapping but your machine will run smoother.
-Mike
Old Jul 8, 2004 | 06:49 PM
  #15
Vinson581's Avatar
so i dont need to pull the pull start and find tdc, i thought that was only for timing
i got the gauge a big 5.99$, and am going to do it after i get the cv joints, and bearings in first. all i gotta do is put the gauge under the tappets, and make sure they are all at spec? dont i need the exhaust ones at a certain point, and the intake ones?
Old Jul 8, 2004 | 07:06 PM
  #16
MJE's Avatar
MJE
yea do a search on this forum i believe the intake is .005 to .008 inches, and the exhaust is like .007 to .012 inches.
-MJE-
Old Jul 8, 2004 | 08:29 PM
  #17
Vinson581's Avatar
got it thanks, how long should it take to do, do i need to remove the frount plastics?
mike you got a aim s/n
Old Jul 8, 2004 | 10:09 PM
  #18
MJE's Avatar
MJE
no you dont...just pull the gas tank cover, remove the gas tank (makes it a hell of a lot easier)
and if you want you can remove the front side mud guards (black pieces near tire area)
-MJE-
freeman34
Jan 8, 2016 11:46 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Brandon400
Sep 5, 2015 08:44 PM
Jason Richards
Sep 4, 2015 06:17 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
