LT250R help
Old Jul 3, 2004 | 11:58 PM
Turq28's Avatar
Default LT250R help
i have an 86 quadracer with sum carb problems. its missing all hoses and i have no idea what goes where. also, the little fitting on the bottom of the carb leaks gas and it wont stop unless i shut off the fuel. and another thing, , i just put in a new FMF fatty and i need to know how to adjust or jet my carb. i havent really done carbs before so this is a little new to me. the carb is the stock Mikuni.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 4, 2004 | 01:51 AM
Michwolv60's Avatar
Default LT250R help
whats up, i am kinda new also, but i can help. the hoses are easiest to look up in a book and see where they go, or maybe someone else can tell u exactly, thats just to much to type for me. the fitting on the bottom is to drain the bowl, so tighten it up and it should stop leaking, and the jetting, this is what fmf sent me for my 90250r
Jetting Information
Main Jet: 240
Pilot Jet: 30
Needle: STOCK
Needle Position: 3RD
Power Jet: N/A
Air Screw: 1.5
Fuel Screw: N/A
It might vary a little, but its a good starting point. hope it works for u
Old Jul 4, 2004 | 03:59 AM
87LT230's Avatar
Default LT250R help
Michwolv60 you said fmf sent you the carb setting, how did you get them becasue I am try to find carb setting for my bike and it have FmF??
Old Jul 4, 2004 | 08:59 AM
sam250's Avatar
Default LT250R help
There are three vent hoses coming out of the carb. They all run to the back of the engine, under the airbox and just end in front of the swingarm. The one coming out of the bottom of the carb is the float bowl vent. If fuel is coming out of there, you need to adjust your float level. Drop 15 bucks on a Clymer manual and it will walk you through it.
2 stroke jetting is not easy. Your best bet would be to have a shop do it for you.
Old Jul 4, 2004 | 10:42 AM
Michwolv60's Avatar
Default LT250R help
i went on their website, and there is a place where u can enter your bike and they will give you them, however i ended up emailing them becuase i have a different carb, however they sent me the ones for the stock carb anyways.
Old Jul 4, 2004 | 03:45 PM
87LT230's Avatar
Default LT250R help
OK thank's Michwolv60 I will see what they say....
Old Jul 6, 2004 | 01:15 AM
Turq28's Avatar
Default LT250R help
thanks for the help guys im gonna pull off the carb and see wuts up. problem.......i have a set of older DG (i think) steel nerfs for my 86, however since my Fatty drops so close to the frame, i cant fit the nerfs in place. now i tried to mount them from underneath the frame....definatley not. any opinions...
Old Jul 10, 2004 | 11:25 AM
87LT230's Avatar
Default LT250R help
Do you have any room under the pipe??
Old Jul 10, 2004 | 03:13 PM
Bubba297's Avatar
Default LT250R help
[i]Originally posted by: [b]sam250
I wouldnt say that it's hard, it's just that they're not very forgiving like the 4-strokes. I would rather do a 2-cycle any day over the hard to get do 4-strokes.
Levi Enstad
Sep 26, 2015 08:00 AM
Halffast17
Sep 11, 2015 02:30 PM
LTqracer
Sport Quads
19
Jun 2, 2004 07:20 PM
donpeter
Apr 4, 2001 12:31 AM
Steve10
Aug 2, 2000 03:32 PM
