Z250 Choke Lever
Old Jul 21, 2004 | 10:17 PM
Aaran's Avatar
Default Z250 Choke Lever
thats how u remove it on the 400. if its the same on the 250 then be careful. the nut is plastic.
Old Jul 23, 2004 | 06:08 PM
hixc's Avatar
actually the nut is nylon
Old Jul 23, 2004 | 06:35 PM
ElectricShift's Avatar
Fix this thing yet?
Old Jul 23, 2004 | 08:54 PM
BrocksZ's Avatar
Still not working. It has to be stuck in the carb or something. The nut that holds the cable onto the carb is metal.
Old Jun 25, 2008 | 09:43 PM
  #15
Raptor0502's Avatar
im having the exact same problem, did anyone figure out how to fix the choke cable? i dont think its kinked, so that must mean the problem is some where in the carb..??
Old Jun 26, 2008 | 10:01 AM
  #16
AdrianXXX's Avatar
Hi,
The choke plunger is probably stuck in the carb due to some dirt. You will have to clean it. But this is not so hard job, I made it on my LTF250 (Ozark) by myself however I am totally unskilled :-)
The only issue is that you have to remove the carb, otherwise you cannot reach the nut.
But removing the carb is not so difficult. It is enough to loosen the carb clamp screws (before and behind the carb!). You do not need to disconnect any cable, just pull it 5 cm out. Then you can reach and unscrew the nut and pull out the plunger. Just be careful when pulling out the plunger, because the spring could shoot. Then clean the plunger and the hole and apply some WD40. Check if it works correctly by pulling the lever up and down (see my video), than remount the whole staff.
Below you can find some pictures of my experiments :-)
I hope it will help...
EIF
Apr 20, 2017 07:15 PM
wrencher82
Sep 30, 2015 04:27 AM
tysonbully
Sep 28, 2015 02:30 AM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
