reverse rev limiter
Old Jul 21, 2004 | 01:29 PM
Aaran's Avatar
Default reverse rev limiter
if i remove the reverse rev limiter on my z, i know i will be able to go faster without bogging. if i do that will i damage my motor if i go faster in reverse?
Old Jul 21, 2004 | 01:33 PM
4xZuk's Avatar
You need a rev limiter on your "posts", Aaran! Yer' dubble postin'!
W/out a tach, you'd be a little harder on it, but back 'er off when the vavles start to float! How much more are you wanting rev out? You'd really only gain some more R's on the extreme top end.
Old Jul 21, 2004 | 01:54 PM
Eric250EX's Avatar
y not just keep it on becuase you can run the risk or damaging or blowing your engin if you over rev
Old Jul 21, 2004 | 03:05 PM
Aaran's Avatar
just a thought to help get out of those mud holes that didnt seem that deep
Old Jul 21, 2004 | 10:30 PM
SukiZ400rdr's Avatar
That is what I miss about my old Mojave compared to the Z400. I could
rev that thing as high in reverse as forward. I am also thinking of
removing the reverse rev limiter on my Z.
Old Jul 21, 2004 | 10:38 PM
Aaran's Avatar
so if u over rev it will u damage the engine?
Old Jul 21, 2004 | 10:58 PM
As far as I understand, there is a way to remove the REVERSE rev limiter.
This is seperate from the rev limiter that kicks in when you get to top
RPM"s.
Anyone can correct me if I am wrong.
But, to answer Aaran's question, by removing the REVERSE rev limiter,
you wont damage your engine.
Old Jul 21, 2004 | 11:11 PM
Aaran's Avatar
i read it somewhere so i know it can be done. it was either on this site or (last letter alphabet then)..400central.com not allowed to type it in for somereason.
Old Jul 22, 2004 | 10:31 PM
craZ400's Avatar
There is an old post in this forum that gives detailed instructions on how to do it, just use your search. And as far as I know, the reg. rev limiter is always there, even if you disconnect the reverse. Even if it isn't, just make sure you're not over revving for long lengths of time and you won't have a prob. If you gun it for minutes on end, then you run the risk of serious seizure.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
