39MM CARB ON AN LT250R
Old Aug 9, 2004 | 12:23 AM
rob02's Avatar
Default 39MM CARB ON AN LT250R
My question is, is anyone out their running a 39mm carb on their lt250r. I just won one off ebay and am waiting for it. and i just read somthing that said that the bigger carb wolnt give it more top end and ill lose my low to mid range power and i dont see how. i should give me more rite? So can anyone running a bigger carb tell me if it really does that or not id really appriciate it.
Old Aug 13, 2004 | 11:17 AM
kdog's Avatar
yes 39MM will work since you have ported and polished your top end. I have 39MM Air stryker on mine and it rips big time.
K-dog
Old Aug 13, 2004 | 11:48 AM
rob02's Avatar
what jets are you running in your 39mm carb main and pilot ? i have no clue where to start at with jetting.
Old Aug 13, 2004 | 01:32 PM
Semms40oz's Avatar
I'm also running an oversized carb(38mm PJ). If you are switching from a mukuni to a keihin then the jetting numbers don't match. I'm running a keihin with a 160 main and a 55 pilot. My setup is as lean as i can safetly go so i'd start with a bigger main, say 180 and work your way down.
Old Aug 13, 2004 | 01:39 PM
kdog's Avatar
My carb is a Kehin 39MM Air stryker I will need to double check what i am running for jets as I do not remember. Im thinking something like 165 -168 or so on Main. Ill check but it depends where you live as well. I live in CA at sea level around 70 to 80 degrees where are you located with elevation temp etc?
K-dog
Old Aug 13, 2004 | 04:49 PM
92Racer's Avatar
I run a 39 PWK, but my ports are highly modified. You won't need quite a 180 jet. I run a 175 and it's still a little fat.. I would start with 170 and go down.
Old Aug 13, 2004 | 11:52 PM
rob02's Avatar
Thanks guys but i have a mukuni carb so the numbers dont match up i live in pa and im running a 390 main and a 35 pilot seems like its running pretty good
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
