1987 lt250r crankcase gaskets/ seals
Are there any gaskets or seals that go between the two crankcase halves? i dont see any gaskets or seals in the schematics on the crankcase on bike bandit .com. There is another post on here where someone's crankcase seal failed. im cracking the case apart to fix second gear,and i want to replace all gaskets and seals. i know there is some compression around the crank,so i imagine there would be a seal there.
no gasket between both case halfs you need to use a special sealer glue. thermabond 321 or something like that?I have at home Ill get back to you the exact name. Stuff is a little pricey $
kdog
kdog
exmotocrosser
Sep 13, 2019 06:12 AM
