NEED HELP FAST ON MY Z!!
Old Aug 23, 2004 | 02:47 PM
STLKR27's Avatar
Default NEED HELP FAST ON MY Z!!
Hi, my step dad and i were out riding yesterday when all of a sudden his Z stalled and wouldnt re fire. the only way i could get it to fire at all was to have the choke open and be on the gas w/o while shaking the bike real hard side 2 side, but even then it died the second i stoped shaking. while doin this their was an ocational backfire. we already know there is no spark but my question is, would moisture in the magneto cause this problem? because as far as we could tell there were no shorts or broken wires anywhere, we also replaced the coil on it with a coil from our other kfx.
Old Aug 23, 2004 | 09:28 PM
bvwarrior's Avatar
check your plug caps, spark plug,, make sure your carb is connected to the motor, and just check everything !
Old Aug 23, 2004 | 10:34 PM
13inc's Avatar
How was it running if you had no spark?
Old Aug 24, 2004 | 12:31 AM
STLKR27's Avatar
we got a brand new plug but when we test for spark there is none, yet when i shake the bike real hard... to the point the rear tires are coming off the ground it will some what fire. it is a spark problem not fuel or air. its also not the coils. 2marro im going to clean the z and remove the magneto cover ta cheak it out
Old Aug 24, 2004 | 12:36 AM
mucky's Avatar
sounds to me the mag came loose inside and is shorting out and also check the cdi box to make sure its pluged in all the way
let us know what you find out
KEEP THE RUBBER DOWN AND YOUR FEET IN THE AIR
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Irishman301
Sep 23, 2015 01:47 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
