Top speed of z250 with dg slip on??
Old Sep 13, 2004 | 10:50 PM
styelz's Avatar
Default Top speed of z250 with dg slip on??
After u get an exhaust jets and filter on ur z250...theres not much more u can do to it that would make it faster so i wouuld say go with it
Old Sep 13, 2004 | 10:52 PM
Rottweiler's Avatar
Thanks for your quick response. I guess that's where I wasn't sure being new to the modifying end. Your saying I should rejet it or just get a good air filter to use with the Yoshi?
Thanks!!
Old Sep 14, 2004 | 04:28 PM
styelz's Avatar
got the air filter before i got my pipe.....if u orderd the comition pipe form yoshi...then u have to jet ur carb like i did.....but if u got the team suzuki yoshi...then u dont.....i would say go with both jets and filter just to be safe.......i recomend u dont try jetteing ur carborator if u dont no wut ur doin.....talk to ur local mechanic
Old Sep 14, 2004 | 04:46 PM
MBrooks420's Avatar
Jetting for a pipe and filter isn't very difficult. I wouldn't take it to a mechanic without trying the do-it-yourself method that cost under 15 bucks.
Old Sep 14, 2004 | 05:06 PM
  #15
Rottweiler's Avatar
I'd like to try it myself for sure. Is there any good how to site out there to learn a bit more on jetting?
Thanks alot!
Old Sep 14, 2004 | 05:51 PM
  #16
radfastdude7777777's Avatar
If you get a pipe and filter you need a jet kit more then with just the pipe. It increases more air flow with less gas, causing your quad to run lean, and without the filter it would be less lean.
Pehter
Oct 3, 2024 11:00 PM
Jeff Roper
Feb 1, 2022 11:48 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
ReconBayou
Sep 23, 2015 02:41 PM
Brandon400
Sep 5, 2015 08:44 PM
