Z400 prob
i took my Z400 out today for a ride and about the end of the ride it starting cutting out and stalling.....i took the plug out and checked it and it looked like it was time to change it so i put a new one and it ran for about 20 more min then started doing the same thing.....so i switched the fuel over to prime to see if it would run and it was fine so i drove it back to the truck.....now it will only start and run in prime when the motor is warmed up.....will start with the fuel switch in the on position.
n e suggestions?
n e suggestions?
i donno but my eiger does this too so it must be a blockage in the gas tank or main jet, i turn it to prime and turn the choke on to make it home but it hasen't done it for a long time so i am not concerned anymore
thanks for the heads up....gonna be tearing it apart tomorrow and checking it out....i had her running a little bit earlier and it sounded like air was getting sucked in somewhere......so i may have a vacuum leak somewhere....i will post an update when i figure it out
its got an inline fuel filter......filter is as clean as can be
it was wierd how it happened.....first 30 or so hrs on the bike it ran perfect.....ran great all day today cept the last hr and it just crapped out
hope you find the problem and its not to expensive to repair
nothing worse than having to fix something when its not wery old
but then again I started changing my quad the day I bought it
yeah....i can't wait to start modding mine
so far its just a rack and skids
but ive ordered the FMF Power Core 4 full system with K&N intake and full rejet kit
and im gonna pick up some new heel gaurds and the IMS pegs
also prolly gonna go with a high comp piston and maybe even step up to the 440 kit....i need something reliable though so im not sure about boring it out yet
im hoping its gonna be an easy fix....i will find out in a few hrs when i start tearing into it
i cleaned the tank, carb and all the hoses plus cleaned out the swtich for the fuel and it was hella dirty in there.....so i made a cover for it cuz it seemed thats where the dirt was entering and clogging it up.....rode it around for a bit and it ran fine.....gonna go hit the trails now and see how she does......but initial ride was excellent
