T1500 Superwinch - enough for an Eiger 400
Old Aug 31, 2004 | 03:44 PM
GixxerJim's Avatar
Default T1500 Superwinch - enough for an Eiger 400
I bought a new Superwinch T1500 for $115 at a local store and am having second thoughts. Generally I will be using it for plow duty and if I get stuck, utility around the 2 acre yard, general use ice fishing hunting etc...
Old Aug 31, 2004 | 04:16 PM
03hmfz's Avatar
It will hold up just use a pulley block everytime. It will double the strength of the winch. It will also put less stress on the winch.
Old Sep 1, 2004 | 09:18 AM
GixxerJim's Avatar
okay, I am an idiot, what is a pulley block?
Old Sep 1, 2004 | 10:58 AM
2cent's Avatar
A pulley block can be used to double the winch's capacity by simply attaching the pulley block's hook directly to the load and the winch's hook to a sturdy mount near the winch.
A pulley block will double your load but will also cut your winching distance in half.
Here is a site with the Pulley Block (2227a) recommended for your Superwinch. www.bargaintools4u.com/p/Pulley/ Take a look at the pics and I think you will understand how it works.
Suzuki recommends a 2500lb winch for the Eiger.
Old Sep 1, 2004 | 11:25 PM
Mars's Avatar
A pulley block is good. It should get you out most of the time on its own. The hardest part is finding something big enough to tie onto.
I have one on my Foreman 450, almost three years old, so far so good.
Hondapolaris8596
Jul 28, 2016 03:17 PM
panicmanic
Dec 15, 2015 01:58 AM
MNatv89
Aug 10, 2015 02:20 PM
baysport
Jul 23, 2015 11:37 AM
CTATV
Mar 22, 2001 09:28 PM
