Quad Racer 450
Old Oct 13, 2005 | 05:20 AM
  #21
bassetboy55's Avatar
Default Quad Racer 450
what kind of torque and power is it putting down, and where in the rpms? Jw if its gonna be like the yammy quick revver or the honda smooth power?
Old Oct 13, 2005 | 06:42 AM
  #22
GE4x4's Avatar
Originally posted by: flynhi250r
Originally posted by: GE4x4
Originally posted by: 1BAD250R
I think its an incredible looking machine, once you take the headlight out. That blue frame is sharp looking. I don't see why everybody complains about the width for trail riding. A lot of XC racers put +1 a-arms on their quad anyway. That brings the width, generally, up to 48-49 inches. The Suzuki comes 49 stock, so its right in the ball park. Switch out those 18' rears for some 20', and you have the baddestall around quad.
XC racers do not put +1 a-arms on. 48-49" is crazy for racing XC. Most have theres set up to be at 46-47" wide at the most.
I run +1 Long travel Housers an my GNCC Z400 and it works out just fine. Most of the pros are running +1/2 or +1.
If they do run them, then they go with 4+1 rims to keep it narrow. What is your width in front in rear? I've raced many races and 46" is the most common width.
Old Oct 13, 2005 | 10:14 AM
  #23
flynhi250r's Avatar
Look the stock z400 front wheels = 3.875" + 1.625" off-set so you won't gain much with 4 to 1's but I do run them. The width at the front is 47.5 and the rear is 47 even, this allows the rear to break loose when I need it to and gives more positive responce from the steering. I ran Powerline this past weekend and have run Sparta, and Loretta Lynns along with most of the Mid- South series plus some at Casey and the Saluki 100, the only people you see at 46" are running stock suspension the Z400 is at 45.9 and the yfz is 46.1.
Old Oct 14, 2005 | 03:43 AM
  #24
1BAD250R's Avatar
Down here most run a +1 set-up. My R sits at 48' in the front and slightly narrower in the rear. Its wider than most but I have no problem in the trails. And when theres a wide open prarie I can take those turns harder for the pass.
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Ashley S
May 29, 2017 10:54 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
