Over tighten oil Resivor Bolt on my Z-400????
the tube is part of a cold air intake for a honda civic lol you can find that tubing anywhere, you just get a piece of flexible rubber that is included in most car intakes to connect the carb to the tube with hose clamps. It flows MUCH better than a K&n with no lid.
#15
the intake is held on by a large zip tie that we put through a bolt on the cross brace and all the way around the tube, it sucks the tube up against the brace so we out a strip of felt where they come in contact which each othe so neiter one will wear. the cdi is mounted on a small tab thats on the subframe.
#17
when you run a fcr40 and this intake is when you will notice the big gains. With the stock airbox set up with no lid and a K&N we could not flow enough air to draw enough fuel from the main jet regardless of how big we tried we were running a 220 main and still had plugs reading lean at one point [img]i/expressions/face-icon-small-shocked.gif[/img] but with this intake it changed everything.
